Post pics of your custom gauge setups
Old Jun 8, 2004 | 06:56 PM
  #51
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Another, closer to show texture.
Attached Thumbnails Post pics of your custom gauge setups-gaugesrightsmall.jpg
Old Jun 8, 2004 | 07:22 PM
  #52
kd5boc's Avatar
Car: 92 RS
Nice...I've been in contact with Josh about his gauges. I ended up making a template from plexiglass and will probably sand/paint it.
What did you use for your texture?
and by the way, NICE LED taillights!!!
Tom
Old Jun 8, 2004 | 09:00 PM
  #53
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Tom
LED tail lights you say? Am I allowed to threadjack my own thread, if so.. please show and tell..
On the gauge tip, has anyone tried the nordskog gauges yet ?
Old Jun 8, 2004 | 10:36 PM
  #54
VictoryIsMine's Avatar
me i am going with the dakota digital stuff and "plug n play" ease..
as far as the LED tails... nice work!!
for those who have not seen them.. any write ups in the future?
Old Jun 9, 2004 | 12:31 AM
  #55
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
How do you get a cluster to look like this?.. I know it's not an overlay, and i dont remember who's it is.
Old Jun 9, 2004 | 01:38 AM
  #56
Car: 1987 IROC Z
!!!!!!!!!!!!!!!!!! I am without words.. someone please direct me to the thread where this happened!!
Old Jun 9, 2004 | 09:13 AM
  #57
kd5boc's Avatar
Car: 92 RS
A site, not thread.
http://thegreatj.cz28.com/
Old Jun 9, 2004 | 12:07 PM
  #58
TheGreatJ's Avatar
No thread involved. I had a spare set of taillights laying around and got a wild hair. It's a big$ job because of the way I made them...that set of lights actually has over 1000 LEDs in it. I pulled the taillight lenses off the housings, laid out a pattern with a magic marker, and proceeded to punch lots and lots of little holes in the lense with my drill press. Then I went to eLED.com and ordered the required numebr of LEDs (and lemme tell you that was NOT cheap.) I stuck the LEDs in the holes, soldered the leads, added the appropriate resistors, and sealed the back of the lense with polyurethane. I put the lenses back on the housings, hooked up the wiring, and stuck blackouts over it all. Voila!!! LED taillights. Total cost was a little under $400.
The bad thing is....I'm going to do it all over again. I picked the wrong LEDs for the turn signals and used too much resistance and ended up with lights that really aren't quite bright enough to be seen in the summer sunlight. So I pulled them back off the car, put my stock set back on, and am about to order a whole new case of LEDs so that I can do it all over with the right parts this time.
FWIW my cardomain site has more and better pics of the car. I haven't updated the cz28 site in months. Also, if you guys had given me the chance, I could have resized the pics.
Oh and I used Duplicolor black aerosol bedliner in 4 thin coats for the gauge panel texture.
Old Jun 9, 2004 | 01:01 PM
  #59
kd5boc's Avatar
Car: 92 RS
That's what I thought. How did you make your panel stick out from under the dask cover?
All I have is the cluster...no gauges yet. (see attached)
Attached Thumbnails Post pics of your custom gauge setups-final-gauge-medium-.jpg
Old Jun 9, 2004 | 06:05 PM
  #60
TheGreatJ's Avatar
That panel isn't going to mount up like mine did. It uses the stock mounting points which is going to put it farther back into the dash....I actually had to cut a couple inches off the back of the trim plastic in order to put my gauges where I did. I also had to make brackets out of bar aluminum and punch holes in the dash behind the panel to make it all stay in place. All this in the name of keeping the panel vertical and making the install look somewhat stock-ish.
But since I was making the whole rig by hand anyway it wasn't that much more trouble.
I'm working on another panel now to mount three 2-1/16" gauges where the HVAC controls used to be. I'll be using an air/fuel gauge, fuel pressure, and vacuum for now. The vac gauge will be replaced with either N2O press or boost press when I decide which way to go with the car. I had them in a 3-gauge A-pillar pod, but I didn't like the way the Autometer pillar fit so I took it out.
Old Jun 10, 2004 | 03:01 AM
  #61
Outlaw87's Avatar
Car: 2002 Camaro SS
Engine: LS1 350 V8
Transmission: Automatic 4 Speed
That one with the gauges under the hood is wild, I dont think I would do it but it was a cool idea.
Old Jun 30, 2004 | 07:29 PM
  #62
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
Hey quadgoat, I just took a look at a pic of your 84. What size rubber do you have on those 15s? Do you like that much meat on those rims?
Old Feb 15, 2007 | 02:20 AM
  #63
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
These are mine. They were in the car when I got it, but I think they look fantastic. They're not super bright at night but they're definitely bright enough, the worst itme of day is the time that this picture was taken, darker than that and everything lights up enough with no problem. And they do look great.
I know they're "silver face" gauges, not sure if they're Macewen's or not.
Coming down I-20 in South Carolina.
By the way, I dont condone taking pictures while driving. Not smart.
Edit:
I got some better pics.
And at night
Seems less bright than stock, but at night your eyes adjust and it's not a problem at all. But with the flash off my less than steady hands make it look a lot worse than it is.
Old Feb 15, 2007 | 02:46 PM
  #64
MacEwen's Avatar
Car: 88 GTA
Engine: 350, 383
Transmission: T-56 & 700R4
If you have clear window for your trip and odometer, they were likely one of mine.
Old Feb 28, 2007 | 10:20 PM
  #65
sprtbikeprinces's Avatar
Car: 1990 RS
Engine: 305 tbi
I found some nice custom face gauges. If interested here is the web site http://www.blackcatcustom.com/ . The guy was real nice to me and it seemed pretty inexpensive.
Old Mar 2, 2007 | 10:05 PM
  #66
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
My overlays were made by Scott at http://www.customgaugefaces.com/. The thing that makes them a little different is that I have a 145mph IROC speedo in my 82-84 Firebird cluster. He was able to custom make them exactly the way I wanted them. I had extra tick marks added to the speedo to make it 150mph and changed the tach numbers to RPM x 1000 instead of RPM x 100 (so the tach numbers are 1, 2, 3, 4... instead of 10, 20, 30, 40... which I never liked).
They match my Auto Meter Phantom gauges perfectly.
Attached Thumbnails Post pics of your custom gauge setups-fb-gauges.jpg   Post pics of your custom gauge setups-interior1.jpg
Old Mar 3, 2007 | 05:52 PM
  #67
Mike1990Camaro's Avatar
Car: 1990 Camaro RS
Engine: V6 3.1L (V8 would be sweet)
Transmission: Automatic (wish it was a 5 speed)
Axle/Gears: Standard Factory Axel
Self made white backrounded gauges.
Not bad for making them just using "PAINT" program on my computer
OH YEA!!!!
Old Mar 3, 2007 | 07:57 PM
  #68
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
here's mine before i painted the mounting plate black and installed them.... if you do something like this make sure to make a cardboard version first to install so you can see where your gauges will be and to make sure you can see all of them....
Attached Thumbnails Post pics of your custom gauge setups-unfinished-cluster.jpg
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Street Lethal
Aug 13, 2015 08:28 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
