Removing door panels with windows stuck up
Old May 10, 2004 | 07:16 PM
Aaron's 87's Avatar
This is harder than replacing the trans. The car is a 91 GTA. The window stopped working, and it is stuck up. I believe the motor is shot, but I cannot even get to it because of the door panel. I cannot get the top piece to pop out. It can't go straight up because the window is in the way. I've tried pushing the window back, prying at the trim from underneath, smacking it out and up, etc. I've got a couple hours into trying to get this damn panel off. When I took it off before with the window down, it just popped straight up with no problems. Any tricks to removing it with the window up?
Old May 10, 2004 | 07:18 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
goto a junkyard and practice
id like to know also because junkyards windows are always up and i need WEATHER STRIPPIN
Old May 10, 2004 | 07:27 PM
MNformula350's Avatar
I took off and put back on the door panels on my Iroc with the windows up....it really wasn't any harder i didn't think. I had to do it that wasy cause the Formula gets the garage, and the Iroc is under a cover in the backyard with no motor or battery.
Old May 10, 2004 | 07:51 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
to get the door panel off press down and out and then see if it comes off.
Old May 10, 2004 | 10:36 PM
you wanna press out towards the door and up to ge them off.
Old May 10, 2004 | 10:42 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
oops my bad
Old May 10, 2004 | 11:40 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Here's the easy way. Open the door. Pull the panel off at the bottom after removing trim and arm rest. Then lift UP on the bottom of the panel as you push the upper trim towards the window. It may take a little while, but it will go. It's a lot harder with the windows up than down..
I had to remove a door panel on a rear door of a 4-door to fix the latching mechanism. If you roll the window down all the way you still get like four inches above the top of the door panel and this is the only way I got it off.
Old May 11, 2004 | 09:08 AM
Aaron's 87's Avatar
I've tried everything suggested, but no luck. Keep em coming.
Old May 11, 2004 | 11:41 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
i did this at the junker to get a mirror off.. i think i smacked it and wiggled it side to side...not sure if i ripped it or not... is there any way to remove that top trim part from the door panel?
Old May 11, 2004 | 11:58 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
There's three notches (kinda) that hold the plastic top part in place on the inside by the window. You can usually get the rearmost one to unclip by pushing down on the top, and pushing it towards the glass. If you get that one undone, you may be able to slide that top plastic piece either forward or rearward to dis-engage the two other notches.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
