Paint question
Old May 12, 2004 | 04:19 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
Paint question
Ok i have an 88 Iroc that has been in several accidents im gussing but the repairs were done right it seems that nothing is missing and what not. but i dove into this project and started sanding the paint, i want it clean real clean. well after starting stripping my hood there are 3 layers of primer and 3 layers of paint stacked! what is the fastest way to strip a car of its paint? i'm thinking sandblasting is the only way to go. what do you think?
Old May 12, 2004 | 07:12 AM
nolanr0413's Avatar
Car: Trans am
with that much paint. what about a stripper to do the job. If i were you i would go to a body shop and ask them what they reccomend and then see if they would sell you the product they use.
Old May 12, 2004 | 12:35 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i think ill go check a couple shops out, if anyone else has had an experience like this let me know
Old May 12, 2004 | 06:46 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
**** sanding, it will take forever to get all that paint off,
Get some stripper, and first go over the hood with a DA sander and some 40 grit should do it, just to brake up the paint so the stripper will work better, then lay it on, let it sit a minute and scrape it all off, then sand the car down, prime, block, sand, prime again, until you are satisfied with the finish, tehn you are ready for paint....
Old May 12, 2004 | 11:21 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i tried aircraft stripper on the hood it would only do one layer at a time. 40 grit works decent but it leaves circles from the sander when it hits metal but i got all those out. theres too many curves to even use a sander on it. im thinkingbead blasted or sand blasted
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
