Flat hood -> Iroc Hood
Car: 88 Camaro SC
Engine: 2.8 ->305->350
I have a spare hood out in the garage, I took the insulation off only to see that it looks like the bracing is all there for holding louvers or blisters it just need to be cut out. ( I know I would need to put some sheet metal down then afterwards so that I'm not getting leaks or anything but, can this be done or is there something that I am missing?
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
um got a pic?
the z28 hood that holds the louvers have the indentation all metaled in there, i would assume it is a diffrent skinning process at the factory and the same base frame work for all hoods. i think it may be alot of work to get the frame work in sheet metal worked out right if you just cut a hole in your sc hood.
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Originally posted by JeffW
um got a pic?
um got a pic?
Iroc8t8
May 4, 2026 08:09 PM
mustangman65_79
Aug 11, 2015 03:17 PM
