rear seat question
Car: 84 Trans Am
rear seat question
My 84 Trans Am project car is missing the rear seat. A buddy is parting out a 85 Camaro. Will the seats from the Camaro fit the TA?? How do you remove the rear seats in a 85 Camaro? Any help is greatly appreciated.
Bob
Bob
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Yes, they will fit. You remove the bottoms by a bolt that faces twards the front of the car, directly under the middle of the seat bases. You will probably have to pull the carpet back.
You remove the backs after removing the bases. Look in the bottom corners of the seat back, where they pivot, and you will see one nut on each side. Remove those, and release the catch (top sides) and the whole thing comes out in your hands.
Good luck
Troy
So Cal
Good luck
Troy
So Cal
1992 Trans Am
May 10, 2023 07:19 PM
