Acrylic Enamel Paint - Need Help!
Old May 20, 2004 | 06:10 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
I'm getting ready to spray can my front ground effect and grill. I could only find one place local that can put paint in spray cans and they said they could only do acrylic enamel in a can.. so no clear coat for me Anyways how long should I wait in between coats with this stuff? Ive used it previously but never on something I was quite as concerned about. Also how long should I wait to wetsand and polish the last coat (I'm assuming its going to be orange peel heaven )?
Old May 21, 2004 | 12:17 AM
jaredjames's Avatar
Car: 1982 Berlinetta
acrylic enamel is still good stuff , there is nothing BAD about it. its just that we got alot better stuff now that we use. if ur usin rattle can you've already ruined it so don't worry about flashtime and wetsanding and buffing. i hope your not lookin for a showroom finish from a rattlecan cuz ur not gonna get it , sorry.
Old May 21, 2004 | 01:04 AM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
If you have a auto paint store around you can get a preval sparyer and you can use the same paint that shops use even BC\CC it works like a rattle can you will have to do more sanding after painting then wet sand with 1500 grit and buff
Old May 21, 2004 | 01:34 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
think about this....
If your going to wetsand between coats....make sure its dry. The longer you wait...the harder it will be to sand. Before I painted my car..the paint shop told me I could sand it in about 2 days...but I waited a week before I wetsanded it..just to be safe. It was probably dry in 2 days.....and it probably would have been much easier to wetsand.
Since your using a can....the paint won't be as thick...and shouldn't take to long to dry....so..just hit with 1500 or 2000 grit between coats..but make sure it's dry...and you'll be in good shape, good luck man
BTW, are you planning to buff it too?
Old May 21, 2004 | 01:36 AM
Car: 92 Z28
yea I was gonna wetsand and then buff it when its done.. cause im assuming the rattle can will be pretty fugly.. I know theres better stuff I could do but I'm pretty broke so this is basically the position im in its got a huge scratch on it so I cant really make it look any worse, so Im just gonna make do with what I can now
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
