HV(no)AC controls stuck after heater core replacement
Old May 23, 2004 | 05:20 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
A few years ago, I had the heater core replaced after it blew apart and dumped the radiator at my wife's feet...
Since then, the air flow control (upper slider) has been very hard to maniplate due to the left hand (red) cable being bound up. (This is why I no longer allow others to work on my cars...)
Any thoughts on where this could be bound up at? I know this is all kind of vague, but at least I could use a few suggestions to begin my search under the dash...
Thanks!
Attached Thumbnails HV(no)AC controls stuck after heater core replacement-redcable.jpg
Old May 23, 2004 | 09:52 PM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
i would just buy a new cable and install it.
Old May 27, 2004 | 08:55 PM
I'm not 100% sure that the cable is the problem. I think it's what's connected to the other end...
Old May 27, 2004 | 09:17 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
During the repair.. w/o knowing, the liner of the cable control could have been kinked. Since the 'cable' is just a solid metal wire (not dissimilar to welding wire) both the liner and cable could have a kink in them. This would be a likely cause of the bind. You could pull the 'cable from the liner and straighten it and the liner as well but, it would probably be easist to aquire a new cable if possible. Just my opinoin though...
Old May 28, 2004 | 05:08 AM
Anybody know where that red control cable goes to under the dash before I start dismantling in the wrong direction?
Old May 29, 2004 | 11:23 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Right below the heater core on the passenger side.Remove the under dash cover & youll see it....
Casey Meyers
Mar 2, 2016 10:46 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Street Lethal
Aug 14, 2015 08:25 PM
