Will old gauges on dash work due to swap?
Old May 30, 2004 | 05:25 PM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
My uncle and I did a 350 TPI swap and im just curious if the old dash is still going to work, the car it's in is an 83 trans am (formerly carbed). I am also curious as to how hard putting a 140 speedo in is, I know that my current one is mechanical and the newer ones are electric.
Old May 30, 2004 | 09:02 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
They should have electrical sensors in your 83 so your should be fine for you guages...I dunno what he did for tach etc, But other guages should be plug and go!
Old May 31, 2004 | 12:42 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The only hookups needed would be for the coolant temp sender unit, oil pressure sending unit, and a tach wire to the negative side of the coil.
The speedo is cable driven, but to swap in an electric unit, you should check this out http://www.hioutput.com/tech/speedo.html
If you're swapping in just the speedo head, you can wire directly to it, but if you swap in the entire cluster, some rewiring is needed. Also the graphics on the electric speedo won't match the 82-84 gauges.
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
beachrodder
Aug 7, 2015 04:27 PM
