rust removal
Old Jun 4, 2004 | 11:55 AM
1quickL98's Avatar
rust removal
Whats the best procedure to remove minor rust and fix small scratches?[IMG]camaro[/IMG]
Old Jun 4, 2004 | 05:03 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Can you be a little more specific on the whereabouts of the rust you have? Since you said small scratches, i'm presuming its the body(exterior). If it's just surface rust, sand it down and check out:
http://por15.com
Old Jun 4, 2004 | 10:53 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I would frist sand all the rust out with 80 grit da then feather edge with 180 grit da and then 320 grit da then prime with a good 2K Urethane primer
Old Jun 4, 2004 | 11:02 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
https://www.thirdgen.org/techbb2/sho...hreadid=243283
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
TheExaminer
Sep 6, 2015 11:40 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
