1987 TransAm Ground Effects
Old Jun 9, 2004 | 07:37 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Going to paint my car soon. How do I get the ground effects off the bottom of the door? I see that there are 2 bolts one at each end of the door (mine are rusted so bad that I will have to grind them off), but what is holding the middle on and how do I get them off with minimal or no breakage? If the mounts and or clips break, so be it, I have devised a plan to rehang the panels if this happens, but I would still like to save as much as possible. There is no need for anyone to use what we call at work "Repair by Hammer".
I have a Haynes book for F-Bodies but it doesn't go into specifics on removing these parts.
Old Jun 9, 2004 | 09:11 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You'll have to take the door panel off. There are 3 more thread cutting nuts inside the door holding it on.
Old Jun 10, 2004 | 04:31 AM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Thanx for the info.
Are the thread cutting nuts on plastic dowls that are part of the plastic moulding? (and going to break off if I try to remove them conventionaly with a socket?)
Old Jun 10, 2004 | 05:45 PM
deadbird's Avatar
Engine: TPI 305/ v6
No problem. The door pieces are actually fiberglass, the 'studs' are metal and IIRC, screwed into place. I'm sure it would be possible to break one if you really try but, thread cutting nuts aren't all that stout (just cheaply stamped out of sheet metal).
Here's kind of how the backside of the fx piece looks...
Old Jun 11, 2004 | 12:16 AM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Thanx for the pic!
That helps out a lot! I thought they were plastic. Looks like it won't be so bad after all.
Hotrodboba400
Dec 10, 2019 07:07 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
billybob6110
Sep 23, 2015 01:30 PM
aharvel50
Sep 21, 2015 07:31 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
