thirdgen shifter in v6 fourthgen??
Old Jun 13, 2004 | 01:22 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
Got a quick question. I already searched for it but didn't find any answers. Will an auto shifter out of a 88 Camaro bolt up and plug in properly in a 2000 3.8 Camaro? There aren't any differences in the mounts or the electrical connections are there? Thanks
Old Jun 13, 2004 | 03:10 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
well, this is quite opposite of the research i had done, but i migth be able to give some light on the situation anyway. To answer the Questoin, yes, it will bolt in (or atleast it should bolt in) Also, the connectors should be the same (atleast i believe they are, but i'm not 100%) When i was doing my 4th gen auto console swap, people had mentioned getting a 4th gen shifter to replace the thirdgen one,which would therefore mean they're interchangeable, or atleast can be w/ some modification. The only problem i see is that a 4th gen auto shifter is shorter than a thirdgen counterpart, which is why using a 4th gen shifter in a 4th gen autoconsole ( in a thirdgen) is recommended as it allows the console to sit closer to it's stock height, with less modification to the actual shifter, as a result of using the 3rd gen shifter in the auto console, you'll end up having to either trim the 4th gen auto console to clear the shifter, along w/ trimming the shifter to fit under the console. I'd highly recommend hitting bone yards, and finding a shifter for a 93+ v6 camaro/bird as they litter the yards here. If you can't find one, you can hire my services and i'll pull one from St. Louis and ship it to ya.
Old Jun 13, 2004 | 06:13 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Sorry guys but you know the rules. This is not REALLY thirdgen related.
Smokin87TA
Apr 29, 2007 09:34 AM
nicksL98
Feb 27, 2007 08:59 PM
blue86iroc
Brakes
23
Jun 14, 2006 04:14 PM
1-MEAN-T/A
Dec 23, 2005 02:26 PM
Cornflakekid
May 14, 2001 02:21 PM
