'89 RS Camaro - 2.8L MPFI... Gauge cluster doesn't work...
Old Jun 25, 2004 | 03:07 PM
Mr_Metal's Avatar
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
OK,
I've finally got this car running the other day, to find out that the ONLY gauge that works is the Amps (ammeter) gauge.
The oil pressure gauge is pegged down at 0 (doesn't move), the fuel level gauge is pegged ABOVE full, and the tachometer registers 4500 rpm @ a true idle of about 900 rpm.
It's ALL screwed up !!
Has anyone had this sort of problem and remedied it w/ a new instrument cluster ?
Additionally, the factory radio isn't keyed ON... it will operate w/ the key out of the ignition. Is this normal ?
The battery goes dead every 3 days if it sits, so I'm thinking that radio may be a constant draw to the battery.
Any thoughts/suggestions to the above mentioned questions?
Thanks in advance for any help.
Old Jun 25, 2004 | 11:00 PM
stiers's Avatar
Sounds like an electrical problem. Check the senders and make sure they are good then move back to the cluster from there. You might want to post or have this moved to the electronics section as well.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
BurlyChev
Aug 16, 2015 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
