SLOW moving power windows...
Old Jun 27, 2004 | 09:33 PM
82crossfire's Avatar
Car: 1982 chevy camaro
Engine: 305cfi
both windows on my '82 camaro move real slow, up/down driving down the road or just got the ign. on. whats the reason for this? are the motors bad?
Old Jun 27, 2004 | 10:00 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
chances are your track and regulator are gummed up. I would take the door panel off and lube the regulator and track really good (clean it all first if you can) and see if that helps. Mine don't move the fastest either on my '90, I think it's just a characteristic of the cars, but if they are REALLY slow, then try a good oiling. If that doesn't work, you may have a window motor that's starting to go bad.
Old Jun 28, 2004 | 12:12 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My passenger side got real slow, then stopped working. Turned out to be a dieing window switch.
Old Jun 28, 2004 | 06:41 PM
LUVmy92's Avatar
Car: Camaro
Its the switch or the motor (pray its the switch!)
Changing the motor is a pain in the ***! Not too difficult but frustrating when you get it put back together and a track pops loose when you test it and you gotta start over!
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 24, 2015 10:11 PM
AkDrifted
Aug 17, 2015 07:45 PM
novaderrik
Aug 10, 2015 12:44 PM
