Swaping speedos
Old Jul 9, 2004 | 04:50 PM
Vaker's Avatar
Car: 1986 Trans Am, 1989 Firebird
Transmission: 700r
Swaping speedos
Is swaping a 85 mph speedo from a 86 Trans Am wiith a 140 mph hard?
Old Jul 9, 2004 | 05:37 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm unfamiliar with TA's, but in Camaros, if both speedos are mechanical, for example, the swap is a piece of cake. Check the opening comments on the following thread:
https://www.thirdgen.org/techbb2/sho...hreadid=249244
JamesC
Old Jul 9, 2004 | 05:40 PM
Vaker's Avatar
Transmission: 700r
Yea see this is were I get a problem...86-92 are not cable driven, They are electrical, and I think they use the VSS.
Now if I get a 87-92 guage and just plug it in, will I have to replace the VSS or will it read accurate speed?
And will the odometer work properly too?
Old Jul 10, 2004 | 06:46 AM
JamesC's Avatar
Vaker,
Sorry, I have no personal experience with your proposed swap. Perhaps you should consider a search if you haven't already. I'm also unsure about the trip odometer since the cluster is electric.
JamesC
Old Jul 10, 2004 | 12:17 PM
Vaker's Avatar
Transmission: 700r
I have preformed a search but it seams that every one who did this swap had a 85, which is cable driven...
Old Jul 10, 2004 | 01:34 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You'll just need to swap in the speedo head and the electronic board for that head. The VSS puts out the same signal regardless of what the speedo face reads; the electronics interpret that signal and send the proper output to the head.
Just five screws on the back of the cluster; two hold the unit in place and three for the electrical contacts.
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TrevinE
Sep 14, 2015 03:20 PM
john204481
Sep 7, 2015 03:22 PM
