Hatch swaping
Old Jul 12, 2004 | 02:28 PM
Vaker's Avatar
Car: 1986 Trans Am, 1989 Firebird
Transmission: 700r
Hatch swaping
Is it possible to swap a hatch from a 86 TA with one from a 89 Firebird?
I mainly ask this because the 86 TA came with the 3rd brake light at the top of the hatch, while I prefer the firebird's which came in the middle of the wing.
Old Jul 12, 2004 | 03:00 PM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
Yup, all hatches can be swaped.
Old Jul 12, 2004 | 03:16 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
you'll have to do a little wiring work, but it shouldn't be difficult at all... make sure you have 2 or 3 people to help you because the hatches are heavy and awkward.
Old Jul 12, 2004 | 03:36 PM
Vaker's Avatar
Transmission: 700r
Cool thanks alot!
Old Jul 12, 2004 | 04:09 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
wiring should be the same. The 86 3rd brake light that sat on the outside of the hatchglass got it's power from the rear hatch cover (the back panel that the hatch motor sits behind).
Old Jul 13, 2004 | 12:20 AM
onebinky's Avatar
I've done it by myself before, just make sure you lay down a heavy moving blanket over the back of the car incase it slips onto the painted area while your moving it around.
Old Jul 13, 2004 | 12:27 AM
86IROCKET-Z's Avatar
Car: 1989 Toyota Supra Turbo
Engine: 7M-GTE
Transmission: R154
Axle/Gears: 3.91 LSD
it can be done on your own, but i stongly recommend having someone with you..
If you drop the hatch, you have one hell of a mess to clean up!
Old Jul 13, 2004 | 12:41 AM
onebinky's Avatar
I agree, If you have a second set of hands definately put them to use. But if you're in a pinch, it can be done.
And yes, I have shattered one before. And yes, it makes a huge mess
When you tighten down the bolts on the rear decklid, start from the inside and go out. I did it opposite, and just as I was snugging up the last nut it imploded. Ever cleaned up 75 lbs of glass chunks before? Luckily I had another spare laying around...
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
formula00ra
Sep 28, 2015 11:50 AM
