Screws for assembling 4th gen camaro seats
Old Jul 17, 2004 | 01:45 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Here's what might amount to be a strange request that I'm hoping *someone* will be able to help out with:
The story:
I bought some 4th gen camaro seats on ebay (the standard black/gray dutone ones). The seller was great and shipped them right off to me, well packaged. UPS, of course, ripped the larger package up in transit, and the zip lock bags that contained the necessary hardware (bolts, etc) to re-assemble the seat backs (front) to the bases fell out of the package. I'm not counting on UPS being able to find these.
The request:
Can someone with these seats oblige in sending a manfiest of the bolts required to bolt the seat backs to the bases so I can replace these?
This would require the kind person to, on one seat only, pull each screw that holds the back to the base and measure the thread and length.
I know, this is a lot to ask, but unfortunately you can't walk into a dealer and ask for the "bolt set that holds the front seats together". =(
Old Jul 18, 2004 | 11:31 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i had the same problem i used my old seat bolts for the halves no problem.
jeff
Old Jul 18, 2004 | 09:51 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
if it was insured you can get ups to pay for the seats....
Old Jul 18, 2004 | 09:53 PM
JeffW's Avatar
Engine: 305 tpi LB9
there only missing bolts....in order to ship they take the backs off the seats to fit em in boxes.
how about an update do you need more help i can always pull mine apart since they are in the basement anyway while i paint the z. let me know exactly what parts you need to see.
jeff
Old Jul 18, 2004 | 11:20 PM
Mangus's Avatar
Transmission: T5WC
Yeah, we're pursuing a claim with UPS, but in the meantime, I'd like to see if I can get the correct bolts.
What's needed:
1 - The two large bolts (per seat) that are the hinge point for the recline, thread and length.
2 - The two (per seat) smaller screws that attach the recliner spring to the seat, thread and length.
3 - The two screws (per seat) that hold in the recliner spring cover, thread and length. I believe (might be wrong) that these may be self taping, or sheet metal screws.
4- One of the recliner spring covers also fell out of the package (I have the RH side, need LH side). There is a part number imprinted in the one I have, but I can't find it at GM. Hopefully it won't be too hard to come by. I figure I should be able to find a torn up set of seats from wich I can grab the missing cover. =(
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
