Need new Door Latches...
Old Jul 27, 2004 | 10:42 AM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey guys,
I have found the problem with my Drivers side door. It has been making LOUD sounds when going over bumps. I managed to go over a bump while looking at the door and saw that the door moved 1/2" up and down from the body at the rear of the door. I thought mabey it was a hinge, but when I had the door open, and pulled up, there was NO PLAY in the hinge. I actually started lifting up the whole car!! I then looked at the latch, and I think I found my problem. The rubber shell that goes over the latch mechinism is gone!! Its completely warn away. So I have decided to replace the latch and see what happens. Where can I get a good replacement? I know I can get one at a junk yard, but I am sure they will have quite a bit of wear on them too!
Mark B
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Oct 9, 2015 10:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
kkirch15
Sep 30, 2015 04:44 PM
