Getting Painted Monday....what to do now?
Old Jul 28, 2004 | 01:29 PM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
I have to give my IROC on monday to the painters...I'm just wondering what I should do to it now & what I've not thought about doing. I have to take the interior door panels off to fix the fabric on them, I need a headliner, the t-tops leak horribly, I have one mismatched front rim from an 88, and the steering column is loose as all hell, etc etc etc...
This in mind...what else might I consider doing before / while the car is being taken apart and put back together? Something that likely would tear up a paint job if done any other time?
Also, what's the best source(s) for new weatherstripping, and any other parts I might need? I saw the t-top door set from gmpartsdirect.com for $193-something. I saw Hawks' headliners and a couple others, all in the 180-200 range. I can't seem to win a single matching rim on ebay, and they're in apparently short supply in the junkyards around the U.S., I guess.
Just looking for some well thought-out advice. Thanks all :rockon:
Old Jul 29, 2004 | 03:01 PM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
No one?
Old Jul 30, 2004 | 09:22 PM
Remyr's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
The rims I know you can get a whole used set of IROC rims from F-Body Motorsports for $400 maybe they can sell you an individual one, or get the set and ebay your three to help recoupe the costs. The t-top seals are $265 for the whole set from F-Body and the headliner can be really cheap to recover yourself if the cardboard is still in one piece, you can get the material from autozone for $30. F-Body sells a kit that comes with a plastic headliner with your choice of fabric color, sunvisors and sail panels for $245, or just the headliner for $150. They seem to be your best bet and are a little cheaper than Hawks for some stuff. Their website is www.fbodymotorsports.com
Old Jul 30, 2004 | 09:26 PM
Remyr's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
BTW I do not work for F-Body Motorsports! I am just down there all the time looking at a bunch of stuff I can not afford. Plus I like staring at the IROC in their showroom that has a LS1/6 spd swap pretending my car looked like that under the hood.
Old Jul 30, 2004 | 09:59 PM
Teal91rs's Avatar
Car: 1991 Camaro *RIP* 1984 MonteCarloSS 1972 Nova
Engine: 355 cid 383 cid
Transmission: TH350 TH350
theres a local camaro salvage yard that may help you www.tacreationsusa.com very good stuf!
Old Jul 31, 2004 | 03:09 AM
Kandied91z's Avatar
strip as much of the car as you can....gfx, doors, hood, etc. take off your interior door pannels as well as the trim on the door sills if your getting them painted.
depending on how elaborate your painting you should disassemble the car as much as possible. remove the windshield, emblems, etc.
if you think it should come off it should....if you think it might come off it should and if you don't think it should come off it still should.
Old Aug 1, 2004 | 09:56 PM
CaysE's Avatar
I highly recommend Hawks over F-body Motorsports. GM Parts Direct and ebay are good resources as well, if you can Ebay carefully enough.
Here's some good info for headliners: https://www.thirdgen.org/techbb2/sho...65#post1905365
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
