Power Drivers Seat Harness...
Old Jul 29, 2004 | 09:00 AM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey guys,
I am installing a new interior into my RS. The new drivers seat is a power seat. My car didnt come from the factory with power seats, but the new seat came with the wiring harness. Is there a factory connector that I can plug this into. I know that all I need is a 12v constant for the seat, but it would be nice if I could just plug it in. If I have to, I will run a fused wire from the battery. Anyone know how many Amps the fuse should be?
Thanks in Advance,
Mark B
Old Jul 29, 2004 | 09:39 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
THere is a single wire (orange or Red) I forget, that runs from under the dash, it plugs in above the drivers side kick panel down into the wire loom, comes out half way back, then plugs into your seat controls. The ground wire is screwed to the floor pan.
John
Old Jul 29, 2004 | 12:23 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
i used my power wire for my window switch. and grouned it off to bolt of the seat. works fine just cant roll my window down while i move my seat and only works when the key is in the on position.
Old Jul 29, 2004 | 12:48 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Power Drivers Seat Harness...
Originally posted by JerseyMark
Hey guys,
Thanks in Advance,
Mark B
Youll have to do your own wiring but GM still makes these power seat connectors. It comes with the connector and about a foot of wiring coming out of it. You would have to wire it from there obviously.
Old Jul 29, 2004 | 04:19 PM
okfoz's Avatar
I still ask, why mess with it, find a doner car, take it from there, I ran 2 of them, one for my 6 way power seat and one for the Ultima style Lumbar Support... only took me about 1/2 hour, no cutting splicing, just inbstall...
John
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
scottmoyer
Aug 9, 2015 10:18 PM
