speedometer question
Old Aug 3, 2004 | 04:12 PM
gilley's86's Avatar
Car: 1986 Camaro SC
Engine: 305, AKA 30WHY
Hey guys. I might have stumbled onto a 145 mph speedo cluster from an Iroc with a 350. Will this just pop right into my 86. Or will there be some difference inbetween because I have a 305 and not a 350. I know its cable driven, but just not sure if anything will go wrong or not. Thanks for the info.
Gilley
Old Aug 3, 2004 | 04:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It'll drop right in. The only thing to check is the location of the trip odometer reset button.
Old Aug 3, 2004 | 04:14 PM
gilley's86's Avatar
Car: 1986 Camaro SC
Yeah, the trip button is in the right spot. I think they changed that after 84. I just had ready something about VSS, not sure what its about or means. Thanks for the info.
Gilley
Old Aug 4, 2004 | 12:06 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Gilley
If its cable driven like you said VSS isnt a problem... cause you car doesn't have it!! Its just a electrical control sensor that reports the speed to the speedometer instead of the cable like you have. I think Dakota digital makes a module that converts the cable to electric.. but you wouldn't need one if its not an electronic speedo.
Old Aug 4, 2004 | 12:09 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, he has a VSS. It's the little yellow box on the back of the speedometer.
Frozer!!!
Jan 19, 2024 04:55 PM
AUZ28
Oct 12, 2015 08:40 AM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
redmaroz
Aug 16, 2015 11:40 PM
