repainting the front clip?
Old Aug 11, 2004 | 02:26 PM
87rediroc's Avatar
Car: 87 Iroc (summer only)
Engine: 5.0 TPI
Transmission: 5 speed
My front end (nose and lower ground effect) is pretty battle scarred. I would like to have it prepped and repainted. Any thoughts on how much this should cost? Trying to get an idea before I go to body shops. Thanks.
Old Aug 11, 2004 | 02:37 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Do you mean the entire clip as in fenders and all or just bumper and ground effects or what? I would do all the sanding prep yourself to save money.. its not hard. If its the whole thing with prep its probably somewhere around 5-600 at a good shop and around 2-300 if your just talking the bumper and stuff with no prep involved. That $60 an hour for labor adds up really quick..
Old Aug 12, 2004 | 08:26 AM
87rediroc's Avatar
Engine: 5.0 TPI
Thanks. I'm gonna edit the original post. I just meant the nose and ground effect. It has a deep scratch (looks like someone with a tow hitched back into me at a lot) and a bunch of little nicks from the 1 winter the car was used as a DD when I was in college ). I'm hoping $300 tops with prep work...
Old Aug 12, 2004 | 04:01 PM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
Well, whatever you do, make sure you use the right formulation of paint for the plastic GFX. It has to use a primer that sticks to plastic, and a more flexible formulation of paint.
When my car was painted, somebody used metal primer and the wrong kind of paint. It looks horrible now and keeps flaking off.
Old Aug 12, 2004 | 04:38 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
The first issue is the fact that there should be no difference in the primer, just the flex agent that is an additive.
Your situation is kind of typical, and is what gives us bodyshops a bad name.
Unless you tried to save some cash and got a MAACO job...
How long ago was it painted? Did you ask the shop to stand behind it?
There is no excuse for a shop skipping the flex agent... these days most of the quality paint companies use a quality flex, and is the shops responsibility to use the product.
Especially on a cover that is as large a part of the car as a third gen is.
Old Aug 13, 2004 | 01:11 AM
Crayz9000's Avatar
Engine: LB9 5.0L
I didn't get the car painted, I got the car that way. All I know is that it has a custom paint job which was done somewhere, and done badly.
I'm just going to re-do the bumpers since the rest of the paint is still in decent shape. There's a guy at a local independent auto parts store who's seen this problem before and has the proper flex agent (I couldn't remember what it was called, sorry).
The only trick in my case is trying to match the gradient job they did, which was basically spraying solid black on the bottom and letting it go thinner as they went up.
Old Aug 13, 2004 | 08:08 AM
87rediroc's Avatar
Engine: 5.0 TPI
Thanks guys. I'll do a search on flex additive and see what varoius body shops say. Can anything be added to the paint to make it less prone to chipping,getting spyders, etc. The nose and lower ground efffect were replaced years ago, but it did not hold up as well as the factory stuff. Thanks.
Old Aug 17, 2004 | 11:16 AM
KEVIN G.'s Avatar
Engine: 305 CARBED
That Is your flex agent, chipability is a factor you'll have to deal with, though, usually a sign of too thick of material. But with all the stuff you gotta put on to make 'em look nice...
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
3tas4me
Sep 4, 2015 01:45 PM
dag19
Aug 26, 2015 10:22 AM
