Firebird Interior Swap?
Old Aug 13, 2004 | 10:36 PM
Bad5OGT's Avatar
Car: 1986 Ford Mustang GT
Engine: 5.0
Just a question, I love Firebirds but I hate their interior. Is it possible to swap Camaro interior into the Firebird? Thanks!
Old Aug 14, 2004 | 04:17 PM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Yep, any 82 - 92 would fit witout any problems.
Old Aug 17, 2004 | 12:19 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
as far as body main tub goes maybe but not as far as minor things like dash pads and such,
they changed them 82-84 then 85-up for both models, and also fenders and so forth all different
etc.
Old Aug 17, 2004 | 04:22 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
interesting... i thought most people (myself included) preferred the Firebird interior to the Camaro. I find the Camaro to be very plain and empty compared to the Firebird. In fact, that was a big reason for me choosing to get a Firebird rather than a Camaro. the dash assembly should bolt up without any issues, you'll just have to deal with wiring. As far as guages, it will be easiest if you get a dash with the same tach setup (ie- stay with what the firebird originally had- be it cable driven or electrically controlled). I'm not 100% sure of the year they switched, but the firebird switched to electonic control several years before the camaro did. Get a camaro dash pad to go with the plastic section and it'll all bolt up. In any case, good luck if you decide to take it on and welcome to the f-body family :rockon:
Old Aug 17, 2004 | 07:26 PM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
I prefer the Firebird's interior too, but he's one of those wierd Mustang guy's .
So anyway, the Camaro went electronic in 1990, the Firebird went electronic in 1986.
Old Sep 21, 2005 | 07:21 PM
NuBird's Avatar
Car: 86 Transmaro, yes I'm for real do a
Engine: 383, 4 bolt block, scat crank, PM r
Transmission: t5 NWC and its holding up behind my
Axle/Gears: 9 bolt aussie, 3.73s from yukon gea
I am doing the camaro interior swap and tonight I am doing the dash. I was thinking the same thing that the dashes would bolt right in but I was wrong. When you take the dash out of the firebird there are only 2 10mm bolts on the bottom corners that hold it to the dash, on the camaro there is a bracket that is spot welded on for the dash, so in order to put the dash in the firebird I had to drill out the welds and spot weld the camaro brackets to the firebird body. Any questions just ask satterlw@bellsouth.net :-D
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
xkingcodex
Feb 12, 2020 07:43 PM
colton_carlson
Mar 8, 2019 12:21 PM
