windshield frame rust?
Old Aug 16, 2004 | 07:26 PM
aberlinetta84's Avatar
Car: 84 Berlinetta
Engine: 305 LG4
The frame around the windshield on a t-top car, if it has rust can it be cured? Theres an IROC in desperate need of some tlc, but the rust around the windshield is kind of scary? I just want to know what would be involved in repairing it, if it can..
Old Aug 16, 2004 | 09:11 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Re: windshield frame rust?
Mine was pretty rotted, it needed extensive metal repair and patching...and a little filling here and there. It can be fixed depending on how far it has rotted.
Before-
After-
Old Aug 17, 2004 | 01:59 AM
Car: 84 Berlinetta
Engine: 305 LG4
what if the part that was red on your car was rotted also???
Old Aug 17, 2004 | 09:14 AM
It was, under those bubbles... you could poke a screwdriver through it. It all had to be cut out and patched with new metal
Old Aug 17, 2004 | 10:40 AM
Night Hawk's Avatar
I've had this happen to 2 GTA's of mine.....I have another now and I'm trying to gather some idea's on how to best prevent this from happening. All the GTA's were hard tops, I'm guessing the moisture is entering through the windshield frame weatherstripping and becoming trapped therefore creating the bubbles.
I am also about to replace the headliner too, I wonder if I could then do something.
Old Aug 17, 2004 | 04:47 PM
Car: 84 Berlinetta
Engine: 305 LG4
so, technically, with a little work, it could be saved then
Old Aug 17, 2004 | 05:22 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
[QUOTE]Originally posted by Night Hawk
All the GTA's were hard tops, . [/QUOTE
i hope you are referring to all your gta were hardtops, because there a quite a few of gtas with t tops
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Fireslash
Apr 11, 2016 06:43 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
