I-ROC Lower valance...
Old Aug 17, 2004 | 09:56 PM
CbrasTsteLkChk's Avatar
Car: '84 Camaro SC/ I-ROC Body Conversio
Engine: Rebuilt 350 5.7L, Edelbrock 750cfm
Transmission: Re-built 700-R4
Axle/Gears: Moser, 3.73
I called the GM dealer and they faxed me a pic showing that the lower valance is connected to the front side fenders (left and right) via a bracket and screws?? Is this right? I thought i was just going to be using bolts and washers. A little help here? Thanks.
Old Aug 18, 2004 | 12:32 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Yeah the sides connect with a brackets that fit in the sides. The brackets have 2 studs on them and they go through the fender and attach with a nut.
Old Aug 18, 2004 | 07:10 PM
89_IROC_98U's Avatar
Yo, Mike
Actually, don't those brackets have 3 studs? I'm almost certain of this (at least on my '89 IROC). Regardless, Mike is right - there is one bracket per fender, and this bracket has 2 or 3 studs with 10mm nuts. The lower valance mounts to this at the fenders, and it mounts to the bumper cover via approximately 500,000 10mm bolts (that should already have washers), give or take 1,000
- 89_IROC
Old Aug 18, 2004 | 07:35 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Originally posted by 89_IROC_98U
Yo, Mike
- 89_IROC
Hey whats up bro I think your right, there probably is 3 studs. I cant remember.
Old Aug 18, 2004 | 07:46 PM
I'm gonna look at it tonight and get the definitive answer...while I'm looking at the 'bird to see where the ALDL connector is
I only say 3 studs because I distinctly recall all 3 nuts being an overwhelming pain in the ***
Heh.
- 89_IROC
Old Aug 19, 2004 | 01:04 PM
3gc's Avatar
3gc
Car: Z28
There is three studs on that bracket. You can get the new bracket for less then $10 a peice. I think $5 each on gmpartsdirect. It's inevitable that those brackets will break on you if you remove the nuts.
Old Aug 19, 2004 | 06:37 PM
Got THAT right, buddy. I sheared off at LEAST one of those studs trying to remove the nuts. Frankly, I'd just as soon remove the 500,000 lower valance bolts TWICE than have to deal with those brackets again Actually, I take that back...I'd rather try to remove my 700R4 bellhousing bolts with a 9/16 stubby than deal with those brackets again.
- 89_IROC
PS - Thanks for the clarification. I thought it was 3 studs, but I wasn't entirely sure after mike83z-28 derailed my confidence with his 2-stud theory
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
