Quick and easy power mirror question
Old Aug 21, 2004 | 05:53 PM
ffvetteman's Avatar
I'm taking the power mirrors out of a 89 Camaro and installing them into my 86 Trans Am. The only way I can get them to work, because the wiring is tied into the power locks, is to have them hot all the time.
So my question is are the power mirrors hot all the time? Can they be used with the key out of the car?
Old Aug 22, 2004 | 08:51 AM
Slow88lb9's Avatar
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Transmission: WC T5 / 700R4
Axle/Gears: 10 bolt 3.73
The key in my camaro has to be on.
Old Aug 22, 2004 | 09:44 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Mine are hot all the time.
Old Aug 22, 2004 | 03:06 PM
Steve86TA's Avatar
Car: To many to list
Are you sure its spliced into the lock harness?They should be a seperate harness.They are all taped together in the door but I think they are seperate.
Old Aug 25, 2004 | 04:20 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I'm with Steve86TA. At least in my 84 TA, the morror harness is separate from the lock harness. I don't see why the camaro would have them wired differently. Even if they're taped together where it goes into the door, they should be separable. As for if they're hot or switched, I'm not sure... i don't have my bird running yet
jaridjohn
Jul 8, 2024 03:49 PM
Dkelz313
Apr 7, 2016 10:38 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
