Rear Tail Light Lens Replacement
Old Aug 30, 2004 | 10:42 AM
FearThisGTA's Avatar
Car: 1991 TRANS AM GTA
Engine: 5.7L TPI
Axle/Gears: 3.23 Posi
Hey guys, aint been here in a while, sorry, but I need to ask a question. Does anyone know how to replace the rear outer lenses on a 91 GTA. I have 2 brand new ones,NOS pieces and my rears need replacin.TIA.:hail: :hail: :hail: :hail: :hail: :hail:
Old Aug 30, 2004 | 11:27 AM
megaracerx's Avatar
well...if its the same as an 86 ta (which i think it is) you have to remove the interior panels in front of the lenses (hatch motor panel mainly) and then just unscrew the wingnuts and pull out..
i hope thats what you were looking for...atleat that how it sounded...lol
Old Aug 30, 2004 | 11:43 AM
Engine: 5.7L TPI
Thanks, actually, I was lookin for how you seperate the 2 halves once you remove them. sorry for the confusion.
Old Aug 30, 2004 | 12:51 PM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
they should interlock with the middle piece that has the hole for your key.
the whole thing should pretty much fall apart into 3 pieces once its out of the car.
Old Aug 30, 2004 | 07:58 PM
Engine: 5.7L TPI
Hmmm, ok, would the 91's and 92's be the same? Since its just 2 separate lens'.
Old Apr 20, 2012 | 02:28 PM
charlie.803's Avatar
Re: rear bulb replacement 89 formula
hey guys, I don't have a turn signal on the left side. The right signal blinks on the dash panel and flashes at the rear of the car. The left signal on the dash panel will not light up and flash when you turn on the signal and will not flash at the rear of the car. QUESTION> what is the best way to get to the left rear bulb to check and see if its bad?hanks, charlie
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
Omega
Exterior Parts for Sale
Aug 10, 2015 10:19 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Aug 5, 2015 08:19 PM
