Prepping a car for paint
Old Sep 1, 2004 | 07:29 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
I have just the factory paint on the car right now, but unfortunatly for me the car was painted in van nuys so i have a flaking clear coat issue, i was planning on prepping the car and sending it off to macco, what steps should i take ? Basically what im saying is how deep do i need to go beore i prime and block sand ?
Old Sep 4, 2004 | 11:12 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You need to sand off all of the offending layer. You can't just sand around the peeling area, because other spots of the same layer will probably end up peeling later on. If the clear is peeling, sand off all the clear and into the base coat. Then use a sealer so that the original paint doesn't react to the new paint. I perfer PPG DPLF Epoxy Primer.
Old Sep 4, 2004 | 11:15 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
If you have the time you might wanna sand the base coat off too. I had some problems with the base chiping off of the primer on my car and its not too uncommon either. But thats alot of extra work too.. up to you.
MustangBeater20
Oct 29, 2022 09:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kah992
Aug 19, 2015 02:55 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
