how to mount overhead console?
Old Sep 2, 2004 | 10:18 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I got a overhead console for a friend, i am re-doing my headliner and im gonna install it in the process. Ive already got the holes cut in the headline but i just need to know what to use to mount the console up with.
Old Sep 2, 2004 | 11:38 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
should come with screws/studs that screw into the roof. check out the tech article on the main page of this site.
Old Sep 2, 2004 | 11:43 AM
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
There are 4 special mounts with screws that thread into the inner roof panel, then the console slides onto those and is held in place with another 2 screws in the dome light area. See the pics in this thread: https://www.thirdgen.org/techbb2/sho...erhead+console about halfway down the page.
When I first installed mine, I was missing 2 of these mounts so I made them by using some sheet metal screws of the right length with a round head, then built the T-shape bushing up with some small washers of different diameters to match the ones that I did have. Worked like a charm.
Old Sep 2, 2004 | 01:35 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Make sure you have the right roof console, too. There are 2 models - one for with and another for cars without T-tops.
Old Sep 2, 2004 | 02:05 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I see the overhead console screws on eBay all the time, so you might check there if you don't have them.
Old Sep 2, 2004 | 10:28 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Yea i may do that because i dont have them. Thanks for the info
Old Sep 3, 2004 | 10:42 AM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
I didn't have the special screws either. I went to the hardware store & found something simular to the orig. screws (bolt\screw). Since they didn't fit the holes in the roof of my car, I just used 'quik jb weld' to mount the 'bolt' (used tape to keep in place, so I didn't have to sit there holding it while it set). You just need to make sure the bolt\screw you use is the right size, to allow the console to 'slide' it into place.
That was over 2 yrs ago.
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
scottmoyer
Sep 7, 2015 07:06 PM
Jetmeck
Sep 4, 2015 12:29 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
