primer/sanding question
Old Sep 5, 2004 | 10:43 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
Should I block sand the primer after each coat or should I do the recommended 2-3 coats first? If I find a low spot while sanding, how do I fill it? Do you need to sand the primer back down to metal before glazing the low spot?
Also, should I tack rag after each coat or just wait till all the coats are on?
Old Sep 5, 2004 | 11:25 AM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
when applying high build primer such as k38 which is made by ppg the best way would be to apply 3 coats at once following the recoat times (5 mins between coats i belive but make sure) then guide coat it with a light fog of sem guide coat black then block with 150 grit to get all low and high spots even if you have any extremley low spots get some polyester glazing putty that can be appliued onto any catalized painted surface. if you have to use any glazing putty then apply 2 more coats and block with 320 then wetsand with 600 then 1000 if u want it to be extremely smooth but 1000 is not nessarcy if you dont have to use any glazing putty apply 1 more coat then sand wiith 320 and 600
Old Sep 6, 2004 | 12:12 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It kinda depends on how long you wait between coats. I've found with rattle can primers that it's better to use a tack rag after I've sprayed my few coats b/c I don't wait a full 30 minutes for the primer to dry. If I sprayed a coat, waited 5 mins, and then used a tack rag, I'd be pulling up primer.
But if you do wait the full dry time between primer coats, then yeah, you should tack rag between coats.
I believe the same goes with color coats, too... if the paint is still wet-ish, you shouldn't use a tack rag. I know House of Kolor - and presumably other paint companies - recommend spraying second and third paint coats when the original coat reaches final tack (very slightly sticky)... so using a tack rag would ruin the paint-job-in-progress.
Don't forget about using compressed air to blow any dust out from door jambs and wheel wells and window weatherstripping and etc..
Old Sep 6, 2004 | 07:33 PM
Car: 87 Formula
Engine: 350 tpi
words of advice dont use rattle can primer!! if u want a professional looking job spray it with a gun
Old Sep 7, 2004 | 03:34 AM
Dave's 89's Avatar
Car: 89 IROC-Z
Axle/Gears: 4th Gen/3.42
This is professional advise. It's the method I use, and the method my dad has used for 15+ years at our shop.
For the love of ***, stay away from rattle cans!
Old Sep 8, 2004 | 04:35 PM
Car: 87 Formula
Engine: 350 tpi
thanks davie i take that as a compliment
jus thought itd be intersting to see wut anyone thought of the fact that im only 16 well 17 today (happy b-day to me) lol
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
