tightening down the tops
Old Sep 22, 2004 | 10:52 AM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
How do I go about tightening down my car's t-tops?
Old Sep 22, 2004 | 12:05 PM
Magsls1's Avatar
Car: 91 Z-28
Transmission: 700R4, T-56 future
if you mean to avoid leaks, from the experience of disassembling my car the only thing I can think of would be to replace the wether stripping and replace to center piece if it is all rusted
Old Sep 22, 2004 | 12:21 PM
Drew's Avatar
The mounts on the body are adjustable, but I wouldn't suggest adjusting them very far from where they are now. Unless they've been moved since the car was new, adjusting them down will put more pressure on the weatherstripping. If the weatherstripping is crushed by the ttops, it won't be long before they leak worse then they do now. Also, as you pull the top tighter, it doesn't line up right at the corners and the windows will start leaking.
Old Sep 23, 2004 | 09:05 AM
Engine: 5.0L 305 H
Water leaks in at the front-outside corners of the t tops, where they meet the window. Is this due to someone tightening down the tops or is it also because the factory left out the secondary seal?
Old Sep 23, 2004 | 09:12 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
most likely the seals are just worn out and shot replace them and it will quit leaking ....
SG91camaro
Sep 5, 2015 10:27 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
