quieting the rattles
Old Sep 29, 2004 | 05:25 AM
Tim Hunsinger's Avatar
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
This is kind of "shade tree", but it is working for me... I've been on a de-rattling crusade since buying a neglected 91 RS. I've replaced/fixed the door hinges, will be getting frame rails soon, and tightened 1000's of loose bolts. Now I have found that descretely dabbing silicone from a caulk gun on loose parts like wires behind door panels, and other areas that I can't tighten with a new screw has made the car much quieter. Also on the ground effects where the little plastic plug things that attach them are--a little silicone there stopped a lot of my outside rattles. I've got more silicone than Ms. Anderson-Lee, but my car is quiet now!
Old Sep 29, 2004 | 08:18 AM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
Re: quieting the rattles
Originally posted by Tim Hunsinger
[B I've got more silicone than Ms. Anderson-Lee, [/B]
Old Sep 29, 2004 | 08:25 AM
cgb's Avatar
cgb
I tell you what will REALLY help quiet the 3rd gen's ( as well as just about ANY other older cars that are prone to creaking and rattling ) is adding sound insulation under the carpet, behind the door panels, and all interior panels....
After seeing / hearing the difference on a 2nd gen I helped restore, I've done this on every one of my project vehicles since.
HTH
Old Sep 29, 2004 | 09:07 AM
Dr G's Avatar
Which sound insulation material do you use? Dynamat? Similar? Which adhesive do you secure it all with?
Thanks!
Old Sep 29, 2004 | 03:57 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Ive tried the silicone trick on my doors and it worked for a couple months and then it returned.. might have been the way it was done or the type of silicone I used, dunno! It definately worked hella good for awhile.
Old Sep 29, 2004 | 10:04 PM
shortyjmg's Avatar
Car: 86 sport coup
Engine: 5.0
Dynamat or brown bread work good
jrdturbo
Mar 31, 2016 02:58 PM
86White_T/A305
Mar 6, 2016 01:48 PM
dimented24x7
Sep 6, 2015 03:51 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Ian Irvine
Sep 4, 2015 08:08 AM
