vinyl dyeing the interior
Old Oct 8, 2004 | 10:33 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
i would like to dye my interior from a pukish beige to a black, will vinyl dye do? or do i have to get some special cloth dye?
Old Oct 9, 2004 | 12:34 AM
Mr_Metal's Avatar
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
Here's a link to the product that I use to vinyl dye vinyl:
http://www.sem.ws/index.php
In my opinion, they carry the TOP of the line vinyl dye.
The key to successful vinyl dye job is in the preparation time and materials that you put into it.
Make sure to wipe down ALL surfaces to be sprayed w/ paint thinner or rubbing alcohol. This step will remove oils, grime, residue from the surfaces... leaving them w/ a contaminent-free surface to spray the vinyl dye.
Wipe them down 2x to be sure, as you don't want to waste your money on a sub-par dye job.
The vinyl dye is about $6 / rattle can, so it's worth it to do it right the first time.
Old Oct 9, 2004 | 07:37 PM
Car: '94 Z28
Engine: LT1 350
ok, but i wanna do the intire interior, not just the vinyl. i want to do the seats, which are cloth, and the carpet, then i'm gonna replace the trunk area carpet with **** carpet so do i need something special for the cloth, or does vinyl dye work also on cloth?
Old Oct 10, 2004 | 10:31 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
You can just get seat covers if you got the money to spend, would look better and come out better just replacing them with the potential color you want rather then attempting to dye them. same for the rug, you can get all new rug for like $300 which will be the road I take when I get to the interior.
Old Oct 10, 2004 | 08:57 PM
Car: '94 Z28
Engine: LT1 350
but that's the thing, i don't have 300 bucks, i got.....not a lot, and i want to dye it so it's the cheap way. so any kinda dye i should use inparticular or should vinyl dye work?
Old Oct 10, 2004 | 09:24 PM
Robg's Avatar
Car: '85 Z28
Plasti-Kote makes a product called 'Fabric Color' that comes in a rattle can. It's for use on carpet, velour & upholstery. I used it on an old cargo security cover with decent results.
RyanJB
May 7, 2016 06:23 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
codeysabatini
Sep 20, 2015 11:36 AM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
