hood won't open
Old Oct 10, 2004 | 09:40 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
hood won't open
Hey all,
I have had this problem whre my hood won't open after I pull the hood release from inside the car. you hear the mechanism working but the hood doesn't pop open. I noticed that if you pull on it from the side and hit the center of the hood it pops open. Any advice on how I can fix this so I don't have to resort to violence everytime I need to re-fill my windshield washer fluid. Thanks
Old Oct 10, 2004 | 10:10 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
oil the mechanism really well and either replace the spring on the latch on the hood or do as many many others do and simply stretch the spring out a little bit to make it longer and make it pop up easier ...
Old Oct 10, 2004 | 10:31 PM
91RSHawaii's Avatar
Car: 1999 30th Anniversary Pontiac T/A
i've got the same problem as you there.
would stretching the spring make a gap between the hood and the front clip?
Old Oct 10, 2004 | 10:33 PM
THEGENERAL's Avatar
no it wont ..only thing that will do that is if you adjust the rubber bump stops on the sides of the header panel
Old Oct 12, 2004 | 05:42 PM
Thunderboy's Avatar
Car: '90 Camaro RS T-Top
Engine: 5.0 TBI
Transmission: TH700R4
I had the same problem when I bought my car. It felt really foolish walking back and forth between the front of the car and putting my arm through the window opening to pull the release lever 7-8 times before I could actually open it!
When I got my hood open (the usual GM soft punch technique a little bit upwards of where the latch is located), I cleaned the latch mechanism with WD-40. Then I applied some light grease to it. I have never had any problem again, and now my hood pops open as soon as I pull the release lever.
Every time I clean my engine, I do the same cleaning and lubing procedure, just in case, and to remove accumulated dirt.
Old Oct 13, 2004 | 05:04 PM
Aredross's Avatar
Car: 1990 RS coupe
Engine: TBI 305.
Well mine doesnt pop when you pull it but it does disengage the lock I just have to pull up on it and it pops up
Old Oct 16, 2004 | 10:19 AM
Incoming's Avatar
Car: 1986 Firebird T/A Streetracer
Engine: V8 350TPI
Transmission: Modified 700R4
lol same problem here what i do is pull the latch and reach around the windshield and bang on my hood twice and it pops open
Frozer!!!
Jan 19, 2024 04:55 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
