squeking rear hatch?
Car: 1991 z28 camaro
I have a 91 z28..at first the squek was minor now its utterly annoying..i cant roll around with a camaro that sounds like its got a mouse in the back..friend of mine has an 84 and he says its the window i was curious as to whether anybody else has had this problem with thier car and if so what is the prodlem and solution thanks to whoever responds
Car: 88 Camaro
Engine: L98 350
Sometimes just open and close the hatch. Maybe a dab of grease on the hook where the latch catches it. Might silicone the rubber weatherstrip.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Check the rubber stops on the corners of the deck lid.Sometimes they just barely contact the body which results in a squeak.
Car: 91 Camaro RS
Engine: TBI
Check out the little hoop that gets hooked into the latch/pulldown assembly, my sisters blazer gets it real bad on that little hoop and the camaro gets a littel squeek now and then from that jsut grease it about 2 times a month.
Street Lethal
Apr 30, 2019 12:14 PM
