4th Gen HVAC Wiring for 3rd gen
Old Oct 17, 2004 | 02:37 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
I havent seen a post explaing the wiring for wiring up the 4th gen firebird (93-96 in my case) to the third gen camaro
Fan speed switch: 4 settings (I, II, III, IIII)
3rd gen wire-----------------4th gen wire
Yellow-----------------------------Yellow
Orange---------------------------Orange
Tan---------------------------------Tan
Light Blue---------------------Light Blue
Green----------------------(conected to level switch: DO NOT CUT)
Level switch: MAX, A/C, DEF, etc.
Brown--------------------------Brown
Green---(conected to Fan Speed switch: DO NOT CUT)
Light Green-----------------Green/White
Rear Defog Button: Lower Left coner of HVAC Panel
Black------------------------------Black
Pink/Black-----------------------Brown
Purple(thick)----------------Purple(thick)
Orange(thick)-------------Orange(thick)
Vacuum line hookups:
3rd gen vac line-----------------4th gen vac line
Purple----------------------------------Black
Orange------------------------------Orange
Red-------------------------------------Red
Tan-----------------------------------Purple
Blue-----------------------------------Yellow
n/a------------------------------------Green
Green vac line just needs to be plugged with a vacum hose line plug. The only time the green will be used is if your orignal def/heat vacuum actuator is replaced with a bi-directional one.
Vaccum info courtesy of Deadbird---Thanks man!!
As of right now I just have to get a s-10 cable for the heat A/C controls and all HVAC will be functional and in working order.
I hope this helps all you future swappers out there or others that have done the swap but didn't know the wiring!
Jason
Old Dec 23, 2004 | 07:42 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
what is power(wire coloror the pin on the connector) into the 4th gen HVAC? i think i better term would be illumination. im not hooking up the controls, but i would like to have the illumination hooked up with my dash lights.
thanks!
Old Dec 24, 2004 | 07:18 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
power to the lights is gray and black is ground!
Old Dec 24, 2004 | 09:58 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
thanks, after looking at it, grey does make since. all the other ill. wires are grey.
thanks!!!
Old Dec 26, 2004 | 12:05 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
No problem! I just hope it makes life alot easier doin this swap!!
Jason
Old Dec 26, 2004 | 01:38 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
ive used your website a few times for reference. nice pics. love the car. the info is out there, but im still using my imagination a bit. ive got some cool ideas for making some bracing out of aluminum and such. ill try to get pics up as soon as i make progress.
thanks again.
Casey Meyers
Mar 2, 2016 10:46 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
jbd1969
Aug 17, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
