Replacing Rubber Seals
Old Oct 19, 2004 | 04:11 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
I need to replace all my rubber seals (T-top, windows, trunk) but not sure where the best place to get the seals is and if i should do it or have someone else do it. Those of you that have done this how much did it set you back?
Old Oct 19, 2004 | 08:27 PM
BRILLIANTRED1's Avatar
Car: Brilliant Red metallic RS T-Tops &
Engine: 305 TBI & 350 LT-1(bolt on's)
Transmission: T-5 & 4l60
1800-999-7474.....ask for web tell him your lats couple vin #'s and order them ...he can get almost ANYTHING he's freakin awesome gets me things all the time ....but i get everything 1/2 off lol ( dads company discount)seriously tho call him ...i dont know about shipping cause i live pretty close to them ...
Old Oct 21, 2004 | 11:15 PM
Anybody know how much this will cost?
Old Oct 22, 2004 | 12:05 AM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
look at spending around id say 300+ to replace every bit of weatherstripping and thats buying it off ebay a lil cheaper than retail in most cases....1aauto.com has all the weatherstripping you could need for a reasonable price as well its expensive rubber
Old Oct 22, 2004 | 12:12 AM
should i attempt replacing them myself or take it somewhere to have it done?
Old Oct 22, 2004 | 12:23 AM
Car: 1989 GTA
couldnt tell ya never have tried myself...i dunno what all is entailed
Old Oct 22, 2004 | 03:04 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
The cheapest place for seals is GM parts direct, also pace performance aren't bad. I would recommend that you fit Genuine GM seals, I know they are a lot dearer but the aftermarket stuff like what you see on ebay just doesn't fit. I replaced all my seals a year ago. I bought aftermarket stuff first. I think they were called softseal. They were a disaster. the doors won't close properly. I ended up throwing them in the bin and ordering genuine GM. It's very easy to fit Genuine seals, I had no problem.
http://www.gmpartsdirect.com/
http://www.paceparts.com/
Old Oct 22, 2004 | 03:45 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
I have soffseal stuff & haven't had a problem with any sealing issues for about a year now Guess some are lucky & some aren't when it comes to aftermarket stuff weatherstripping. But I totally agree also that genuine GM weatherstripping fits the best.
Old Oct 22, 2004 | 04:50 AM
gholian's Avatar
Engine: 2.8 V6
That's good to hear you hadn't a problem. I bought the door seals and window seals. Both were a disaster. There were gaps between the window and the seal that water could get in and as I said when I fitted the door seals I couldn't get the door to close without slaming it hard. It's good to hear that these things work for somebody. If someone wants to fit seals themselves and doesn't want any hassle then GM seals are the way to go in my opinion.
Old Oct 22, 2004 | 07:22 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I have soffseal t-top gaskets and door gaskets on my IROC. I've had friends go through 2 or 3 sets of GM gaskets and still have their t-tops leak, so I decided to use the soff-seal. They seal beautifully, and just press into place. I didn't even have to glue them in.
The door gaskets aren't quite so nice. There is too much material at the top front part of the door on both sides, but it's a spot that's not noticable and really has no effect other than irritating me. Overall I'm not disappointed enough to replace them with OEM, but if I could do it over I'd use OEM door gaskets.
Old Oct 22, 2004 | 11:15 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm replacing mine tonight so I'll let you know. Got them from year one. Hopefully it fits better than their awful carpets.
Old Oct 22, 2004 | 01:32 PM
Car: 89 RS
I did some searching on this topic since it's been talked about before. In conclusion, I think it really is just a hit or miss with seals & weatherstripping. Maybe it depends on where it was made, etc. etc. lol! Oh well. I too will stick with Genuine GM the next time I have to do all my seals. I'm just glad my seals worked out for me after hearing the horror stories from others with the same brand. hehe
Old Oct 22, 2004 | 09:44 PM
Camaro_nut's Avatar
Just to throw in my ,
I had replaced my T Top seals with Factory GM. Was not easy
removing the old sealant inside the channels! I spent about
an hour or so scraping the crap out! Installing took half the
time than removing/prepping! These were done over a year
ago. Since then no more leaks ( knocking on wood!). I also
replaced my T top bar as well. It got rusted out. That too,
was a brand new GM replacement part. So far so good. No
problems. For my doors, I also used brand new GM replacement.
No problems there also. Everything fit fine.
On my rear hatch seal, I went with Soffseal from 1aauto off
Ebay. That too has held up fine. All my seals are held in with
silicone sealant. So it helps keep the weatherstripping in place.
Old Oct 22, 2004 | 11:36 PM
Car: 86 T/A
Engine: HSR 355
Well I almost finished one side. It got dark so I just quit for the night. It looks great and is going smoothly except the front piece that borders the windows is a pain. The one corner is a bit larger than stock but I don't mind, I'll just glue it down a bit more. I reccomend the kit from year one if they still offer it. This thing is a few years old.
Old Oct 23, 2004 | 12:05 AM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
man i wish i just bought a freaking hard top... lol... these damn t-tops prob will never stop leaking... i have the worst luck...hopefully after the 400 and some bucks i spent on my stripping...i wont have the nice smell of mildew every time i open the door.... how refreshing in the morning... who needs a cup of coffee when u got that to wake your a$$ up.. lol
Old Oct 23, 2004 | 08:42 AM
Car: 86 T/A
Engine: HSR 355
$400? That sounds a bit steep.
Anyway, just buy some caulking for a temporary fix. It worked for over a year but I don't want to push it so I'm replacing it all.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Leggman1
Aug 6, 2015 04:15 AM
