how do i get this stuff off??
Car: 1983 Z28
Transmission: TH350
i need to get all the plastic panel on the drivers side in the trunk. u know were that little storage box is. i have to get to the top of the rear drivers side wheel well, can someone tell me how i am suppost to get in there?? its easy on the passanger side, but i cant find the end of the driver side trunk cover.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You have to remove the ,A-pillar blk moulding,6x9 speaker cover,the overhead plastic(above the Rr seat),Dr side seat back striker(if it has one)Round support mount cover(luggage shade),Hatch strut striker bolt covers,Rr compartment panel(behind the taillamps)& storage compartment door/lid(if you have one).Heres the tricky part.There are 2 plastic screws(same type as door panel srews basically) between the luggage shade mount & the stowage box.If you pull off the rubber weather strip for the hatch glass.Youll see them in the gap.Rotating them usually works them loose.Disconnecting the stowage box from the plastic panel.Sometimes makes it easier for removal/install.Its held on by three Speed nuts & ONE STAPLE(on the forward facing side of the panel).Dont forget the phillips screws also...........
LT1Formula
Oct 8, 2015 08:34 PM
