rear wing holddown bolts broken off
Old Oct 24, 2004 | 01:09 PM
XspyderX's Avatar
How does one go about repairing broken bolts that attach the wing to the rear hatch?
Old Oct 24, 2004 | 01:11 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
wing, what f body has a wing?
if your talking spoiler, you just take the bolt out from under the hatch and put a new one in, worst case you have to drill it out
Old Oct 24, 2004 | 01:37 PM
XspyderX's Avatar
Problem is that the head of the bolt is in the spoiler not inside the hatch. inside the hatch are nuts on the bolts.
Old Oct 24, 2004 | 04:09 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
hmm, that sounds like a real pita
know anyone who welds?
Old Oct 24, 2004 | 09:05 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Are you talking stock here,if so.Remove the "wing" if you can.Then remove the nut & bolts from.Then apply some fiberglass to the hole where the bolt was.Reinstall the bolt.Let the glass cure(better if you wait overnight) or a day.Then put it back on.Worked for me .
Old Oct 24, 2004 | 11:49 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
GM on spoilers decided to use studs, not bolts. They have one type of thread on one end that goes into the spoiler. Then there is a lip, so it only goes so far into the spoiler, then additional threads on the other end... Typically the end with the thicker threads is screwed into the spoiler first. This leaves a stud then coming out of the spoiler. Which is then installed and a nut is run on from the bottom, under the deacklid to hold it on the car.
This works great unless someone over tightens the nuts, or they rust or seize on. Then what will happen is the other threaded end....(in the spoiler will back out) What you can do if this is the case....
Take off all the nuts you can. The ones that will not come out. Turn them in the way that they are loosening the spoiler...you should be able to back them out of the spoiler hole enough to free the spoiler. Then you can get a pair of vise grips on the stud sticking thru the decklid and hopefully hold it tight enough to be able to free the nut under the decklid. Sux you may end up needing new studs in the end.
See if that works...
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Eric-86sc
Apr 3, 2016 03:52 PM
hectre13
Aug 26, 2015 08:17 AM
