Z28 Door alingment?
Axle/Gears: 3.45, 3.27, 3.27
You can un-bolt the door hinges from the body and shim them. But before that take a look under the fender. If the lower attachment point is folded over I'd suspect that someone improperly lifted it from that location. If that was the case, your fender has been bowed out in the middle. Un-bend the tab, then you'll need to adjust the fender.
Lon
Lon
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Werid, my passenger door (which was replaced by the previous owner with one from a junker) sticks out like 1/4 of an inch towards the quarter panel. Towards the fender its fine. I just ordered 2 lower door pins so im gonna fix this crap once and for all. How do I align the door to match it up with the quarter panel?
ambainb
Apr 25, 2016 09:21 PM
