dashpad....
Old Oct 25, 2004 | 11:20 AM
solty202003's Avatar
Car: 1990 Camaro IROC-Z
Engine: 5.7L
dashpad....
Ok i usually don't post here a lot but i am trying this out because obviously i own a thirdgen!! Anyway i figured you guys could help out more then the camaro z28 forum. Like many i have a cracked dashpad that is very ugly and i was trying to think of ways to fabricate something out of it. I was thinking of trying to use some type of filler to fill the crack in smoothly and then sand the whole dashpad smooth. After sanding it smooth paint it with like a gloss or flat black then after that hit it with a coat of clear coat to finish it off and give it a professional look. Tell me what you guys think and throw any ideas that you have at me !! Oh and if i did that and it looked good, then i would do the piece around the heater controls and then the shift plate to match.
Old Oct 25, 2004 | 02:29 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If you can pull it off it would look good. Some problems I could possibly forsee:
Since the dash pad was originally covered with Vinyl, you would have to use something that would be flexable. They do make a urithane repair kit it for bumpers that would probably flex enough, but it has to bond to the vinyl. Problem being if the filler is not flexable then it would crack when you put any pressure on it.
When these things crack it seems that the cracks raise on the edges so you would hve to cut away more material to get it smooth.
Its worth a shot.. Tell us how it goes.
John
Old Oct 25, 2004 | 07:35 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Time for over priced used replacement from ebay, or over priced used replacement from the classifieds here.
Once it is cracked there is nothing you can do repair it. I would say good luck but on this one I'd say exercise the wallet.
Old Oct 26, 2004 | 12:15 AM
Mr_Metal's Avatar
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
I'm STILL doing the repair on my 'cracked' dashpad, just like hundreds of other 3rd Gen members (time has NOT been permitting) !!
Long story short...
I have a length of black interior vinyl (my Aunt used to work for Ford Motor Co. back in the day).
I'm going to strip off the old brittle, cracked, fubar'd dash vinyl and adhere this NEW vinyl to it... and post pics of how it turns out.
I'm thinking/hoping that others can purchase the vinyl from an interior shop/wholesaler and do the same way as well.
Pics/info to follow...
Old Oct 26, 2004 | 12:43 AM
samdog1232000's Avatar
Car: 92 RS 25th Anniversary
Engine: 350 L98 w/Vortec Heads
Transmission: 700 R4
I would check out some local junk yards... Surprisingly I found 3 dash pads at that yard not cracked.... They were dirty like no other but once I cleaned them and put a proctectant gel coat on them it looked like new..... I got them for $25 bucks a piece.......
Old Oct 26, 2004 | 12:50 AM
Car: FBODYS
Engine: ALWAYS 8'S
You will NEVER get the corners and speaker grills right. If you have enough money for a vacume forming machine you have enough money for a better condition dashpad. PERIOD.
Old Oct 26, 2004 | 05:46 AM
3rdgenstm's Avatar
Car: ‘92 Z28
I have seen a formed plastic overlay that attaches to the pad with 3M VHB double sided tape. I think it was about $75, but you could pick up a good used one for that much. Do a search on ebay for the overlay.
Old Oct 26, 2004 | 07:10 AM
okfoz's Avatar
I have a list of parts that I get whenever I go to a junkyard. wether I need them or not... An uncracked good condition Dashpad is one of them... I get them ALL if I got the money (luckily I know the owner of the junkyard I visit ) BUT like a moron I neglected to get some Formed Plastic interior door panels before they were destroied oh well
John
Old Oct 26, 2004 | 11:06 PM
Engine: 5.7L
care to hook me up with one next time you go to the junkyard? maybe a little cheaper then the rest?
ranone21
27
Sep 24, 2007 09:51 PM
sweetpea12
Exterior Parts for Sale
Sep 15, 2007 03:00 PM
