Huge Rust Holes. Can I patch with fiberglass
Old Oct 31, 2004 | 03:47 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Basically the corner of her driverside floor board is gone, also with rocker panel and a hole below her window edge. Can we patch with fiberglass and goop some paint on. Nobody is going to see it. yes no?
Old Oct 31, 2004 | 05:12 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
it won;t last and will seal you problem in further. you would be better off cutting out the bad rust and patching in some panels. that is the more permanite way. if you don;t want a real fix you could just slap that stuff in there and forget about it for a year or two untill the rust eats around you patch job.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
