orange peel and runs
Old Nov 1, 2004 | 08:07 PM
BRILLIANTRED1's Avatar
Car: Brilliant Red metallic RS T-Tops &
Engine: 305 TBI & 350 LT-1(bolt on's)
Transmission: T-5 & 4l60
i finally got my car back after 4 months of painting....sucky slow painter....well it has some orange peel and rund how do you go about sanding the things out please post them is the steps of each process THANKS
Old Nov 2, 2004 | 02:55 PM
JohnyJacknife's Avatar
Car: 1991 Red Camaro RS
Engine: 305 TBI
There really aren't alot of steps.
Step one: Wet sand with a hand block and 1000 grit sand paper.
Step Two: Buff.
Now if you can buff, good. But if not find someone who does 'cause there stands a chance that a novice can burn the paint. Painting is easy, getting the paint job to shine isn't as easy.
Old Nov 2, 2004 | 04:07 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
I'll give you a hand also...
Good advice...
Not too bad, but it begs the question... how much paint is on the car...ie; how many coats???
Base clear? single stage?
Are you lookingf for a show finish or just gloss? 1000g is kinda coarse unless you're buffin' your *** off. 1500g or 2000g, is preferable for base/clear depending on how dry the paint actually is. (by dry I mean how much orange peel not the cure time)
also good advice...nothing can f##k up a paint job quicker than someone who doesn't know how to buff.
Not really, If you've got gloss issues, you're probably using the wrong hardeners or reducers.
good luck, let us know if you need any help.
Old Nov 2, 2004 | 05:27 PM
Kandied91z's Avatar
how is the overall condition of this paint? obviously not to be rude but i'm assuming you didn't pay much if the painter didn't already take care of this for you. it's very easy to ruin a paintjob with a piece of sand paper. if you have absolutely no knowledge i'd leave it alone.
if the paintjob was a $100 quickie and it doesn't matter then go ahead an practice. plenty of tips on the internet as well as here alone to get you in the right direction.
Old Nov 2, 2004 | 06:11 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Read this, this will give you an idea of whats involved.
http://sethirdgen.org/finessing.htm
Old Nov 17, 2004 | 12:24 PM
hasbeen's Avatar
Car: 82z
Engine: oh my 305
Transmission: 200r
eastwood
eastwood makes a gizmo that will shave off paint runs. works like a wood plane
Old Nov 17, 2004 | 02:07 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
take it to a place that'll clean it up and buff it for you
Frozer!!!
Jan 19, 2024 04:55 PM
89GTAOz
May 16, 2020 09:31 AM
tnrednneck
Aug 13, 2015 08:57 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
