Underside floor pan damage?
I have a '91 Camaro Z28 with underside floorpan damage. Some time ago, I took my car to have the underside of the engine steamcleaned. The facility where I took my car didn't have a rack so used floor jacks to lift it. On the passenger side they lifted up the car where the subframe connector and the floor pan welded together and bent the sheet metal where the side ground effects mount on the back side of the front fender. I will send some pictures to give all of you a better understanding of my situation, by the way how do I send pictures?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
When you post a reply.There is a box thats says"browse".Click on that.You should have a folder or file with your pics.You can post apic here for every one to see.
Re: Underside floor pan damage?
Sorry it has been a long time. Finally I have a photo of the underside damage. I'll take another shot at another angle, soon.
Car: 87 Camaro IROC
i think i know what you are talking about, i have bent the joint as well, but im curious to find out what your question is. if you are looking to cut out some rusted parts, then cut them out, straighten the good steel, and replace rusted parts with either fab'd steel or cut it from a good doner car.
