tire hitting aero ground f/x
Old Nov 3, 2004 | 01:40 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I just recently installed the '90-92 aero ground f/x on my '86 sportcoupe. I have 255/50/16 tires all around on '86 IROC wheels. The rear part of the front tires hit the rocker panel ground f/x pretty good now when I turn the tire sitting still. Looking at my clearance in front and behind the tire I have lots more clearance in front of the tire then behind it. Shouldn't the front tires be centered in the front wheelwell?
Has anyone else seen this problem when upgrading to the newer aero style f/x? I don't have any bent front end parts as the car drove perfectly straight, no pulling or vibrations. The whole steering was replaced with the PST kit.
Old Nov 3, 2004 | 03:21 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
The clearance issue is not that uncommon, it's the shape of the later GFX. It sticks into the tire area further than the ealier style that was square instead of curved. Does the car normally sit that high? If it was a little lower it would clear easier, if you look at the design of the GFX you will see what I mean.
Old Nov 4, 2004 | 01:31 AM
Engine: 4.0L
I understand that the aero f/x is slightly longer then normal f/x slightly and protrudes into the wheelwell some but didn't '90-92 cars with the aero f/x come with 16" wheels also? This shouldn't be a problem.
My car sits at stock ride height. It looks higher then it is because of the camera shot, I was laying down trying to get a picture of the front tire not centered in the wheelwell. I know it's stock ride height because I just installed replacement springs all around (MOOG).
Is is possible that my caster needs adjusted to properly center the tire in the wheelwell?
Old Apr 7, 2005 | 12:06 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
ttt
Old Apr 7, 2005 | 10:55 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
when is the last time you had the car aligned? I was messing around with my other car and there is all kinds of adjustment that you can do with the struts. But it would be best to see what your alignment specs are and compare them to a 91-92 see if there is any difference at all. If not go have it aligned. That's all i can think of
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Feb 13, 2016 10:04 PM
skip91
Sep 24, 2015 03:29 PM
formula_novice
Sep 5, 2015 03:58 AM
E Rod
Aug 28, 2015 05:17 AM
