Vent Trouble
Old Nov 8, 2004 | 05:40 AM
90FormulaPROJ's Avatar
Car: Formula
Vent Trouble
For some reason the air only blows out of the defrost no matter where I put the ***. What could cause this?
Shawn
Old Nov 8, 2004 | 10:23 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
1. A bad vacuum connection or cracked/broken vacuum hose under the dash or where it comes off by the EGR solenoid.
2. Bad check valve where the line comes off by the EGR solenoid
3. A bad vacuum dashpot under ther dash (there are like 3-4 or so of them under there)
4. A bad heater/defroster/AC control head in your dash (the thing you use to turn on AC/defrost/heat).
That should just about cover it..... not a fun job under our minimal clearance dashes.
Old Nov 8, 2004 | 10:28 PM
Car: Formula
What should I check first?
Pac J
May 17, 2020 10:44 AM
mrbird
Oct 20, 2015 03:43 AM
kkirch15
Interior Parts Wanted
Oct 15, 2015 02:21 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Lmancha96
Sep 25, 2015 08:11 PM
