90 Camaro Build Date.
Car: 90 Camaro RS, 2001 Holden Calais.
Is anyone able to tell me when this vehicle was built please.
VIN # 1G1FP23E0LL100054
I know its a 90 RS model, and the low build number would indicate it was built very early in the model year, but i need to know exactly when if possible.
Any help appreciated, thanks.
Car: 86 Z28, 2000 Firebird, 2004 SSS
Engine: LG4 carb, 3.8, 6.0 HO
Transmission: Auto, Auto, Auto
Axle/Gears: 3.42, 3.42, 4.10
Here is the VIN info that I got using the VIN Decoder from this site. Really handy for when your going through the Boneyards.
Here are the results for your query on: 1G1FP23E0LL100054
Made in: United States
Manufacturer: General Motors
Make: Chevrolet
Carline Code: F-Body
Carline Series: Camaro (all models)
Body Type: 2 door coupe (hatchback)
Restraint System: Manual belts (driver inflatable)
Engine Code: 305 ci V8 L03 (1988-1992)
0 is the CHECK DIGIT
Model Year: 1990
Assembly Plant: Van Nuys
Production Sequence: 100054
Make: Chevrolet
Model Year: 1990
Thanks JetSet, but i really need to know the month it was built in.
I think i have read that if you contact GM they can search the VIN and give details, but where or who would i contact, anyone know please?
Originally posted by 82RECAROTA
Label on drivers door has the build month. If yours is missing, your build month is 9/89.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Originally posted by V-Car
Thankyou for that info....did you check the vin details to get that month?
I think each year is a little different for the actual day of new year production, but it almost always starts in September, with some exceptions.
John
Car: 88 IROC
Engine: 350 L98
Transmission: T5 - 5 Speed
VIN # Decoder?
I was just wondering how you determined the car was #54 off the line? I see the 100054, but how does that tell you?
What sequence would mine be?
1G1FP23F3ML116551
I just jacked your thread. Sorry. I was intrigued by the outcome of you query and thought I would question while I was here.
Thanks if you know. Or if you could explain how to break it down.
1G1FP23F3ML116551
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
Re: VIN # Decoder?
1G1FP23F3ML116551
1G1FP23F3ML116551
yours was 116551, so your car was 16551 off the line.
hope that helped
Originally posted by okfoz
More like Deductive reasoning, since September "9" 1989 would have been the first month of production for 1990. Since your the 54th camaro off the line, you can probably assume that it was made on the First Day or two of production.
John
John
All 90 Camaros were actually built in 89 i read, not sure how accurate that info is.
It was a very short production run, and only 34,000 odd built that year, and 91 model production started in early 90??
Thats why im thinking that mine may have been built in Aug, not Sept.
Hopefully V-Car will let us know what the Archive has to say.
So now i just have to get it on a ship.
Car is in Japan, im in Australia.
Here is a pic of the car.
GVMV
Aug 16, 2015 08:01 PM
