waa i need this part where do i get it
Old Nov 26, 2004 | 02:22 PM
slim84maro's Avatar
Car: 86 Camaro
Engine: 5.7 with some mods.
Transmission: 700r4 needs shift kit
Axle/Gears: Stock.
ok i had a close call with a tree lastnight. my damage's where. scraping from from bumper to passanger mirrow not that bad can be repainted and be fine.
but my mirrow got the brunt of the pain.
the piece of plastic between the mirrow and door broke i dont know where i can get that?
also i have a dent where the mirrow is, mirrow is scraped and crunched a little, my window its manual power window is hard to roll down and up i notice a little dent where the opening is for the window to go through i think i can pull that out and the dent.
ok so i need that plastic part between the mirrow and door?
and im also wondering if i take my car in to be painted if they will fix that for me like align the mirrow straight and pull the dent?
im getting it painted after winter.
car is a 84 camaro.
Old Nov 26, 2004 | 04:00 PM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
You can get the plastic piece from a GM dealer also I know Classic Industries used to have them in last years catalog so they should still have them. I bought mine from GM just a year ago or so.
Old Nov 26, 2004 | 08:37 PM
AJT86's Avatar
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
maybe GM parts direct?- get the part # from somone and order it
Old Nov 26, 2004 | 11:56 PM
slim84maro's Avatar
Car: 86 Camaro
Axle/Gears: Stock.
yeah i hope so. im gonna look in the junk yards for some camaro and see what i can find.
Old Nov 27, 2004 | 03:48 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
There's a few different once depending if you have manual or electric mirrors. Check my for sale page (link in my signature) about half way down on my parts page you will find a new GM set still in the bag for manual mirrors.
Old Nov 27, 2004 | 09:56 AM
CaysE's Avatar
20366668 is the part number for the passenger side mirror assembly. As far as I know, it comes with the whole mirror and the plastic piece that bolts to the door, but you may want to contact GMpartsdirect.com to see if that truly is the case. I don't see a part number for just that plastic piece.
Old Nov 27, 2004 | 12:35 PM
slim84maro's Avatar
Car: 86 Camaro
Axle/Gears: Stock.
is that what it is a gasket? $10 it says
Old Nov 27, 2004 | 01:04 PM
CaysE's Avatar
What says 10 dollars?
Old Nov 27, 2004 | 01:10 PM
slim84maro's Avatar
Car: 86 Camaro
Axle/Gears: Stock.
for the mirror gaskets. in his sig for parts.
Old Nov 27, 2004 | 03:13 PM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
The gaskets (they are actually pretty thick hard plastic pieces) I use on my 89 for power mirrors are GM #20364442 (RH) and GM #12337844 (LH) and are listed in the GM Parts and Illustration Catalog.
Hope this helps.
Old Nov 27, 2004 | 06:15 PM
AJT86's Avatar
if its gonna be a pain in the *** to get these- i would just make my own get creative its only a peice of plastic or rubber
Old Nov 27, 2004 | 06:37 PM
slim84maro's Avatar
Car: 86 Camaro
Axle/Gears: Stock.
yeah i could do that. but i wanted it to look original
Old Nov 28, 2004 | 02:28 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
GMPartsdirect.com lists them for $2.50 each so piece of cake to just order them from a GM dealer and you're all set
Old Nov 28, 2004 | 08:45 AM
CaysE's Avatar
What's the part number for manual mirrors? The gaskets on jlarrson's site are only like 1/4" thick.
Old Nov 28, 2004 | 10:08 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Ok, looked at this again. The thinner ones (part number 20360560 and 20360561) are listed for 1982-85 for manual mirrors (illustration shows a mirror without electrical or wire driven driver side mirror).
The other (thicker) gaskets 20364442 and 12337844 are listed for all years for all type of mirrors (manual and electrical).
There is also different part numbers for the mirror housings 82-85 (manual with DR1 option code/RPO mirrors) so I guess that is the reason for the thinner gaskets ...
Hope this makes it a bit more clear. I've updated my 4 sale web page to reflect this as well.
Old Nov 28, 2004 | 03:05 PM
slim84maro's Avatar
Car: 86 Camaro
Axle/Gears: Stock.
ok thanx alot i think im gonna order then from gm soon. today im going to a buddys house to bleed my brakes and pull the dent and fix w/e i can now.
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
