Shifter shaft thread?
Old Dec 2, 2004 | 09:58 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I'm almost done gathering parts for a 5sp swap. I had a custom shifter made for another ride that didnt get installed before I sold it. I am wanting to install on this car now. I never had it tapped for the old ride, so I can tap it for this one. However, I dont have any taps or dies that seem to be fitting.
Anyone know what threads this is so I can get the proper tap? Is it different per years?
Old Dec 2, 2004 | 10:54 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
16mm x 1.50 .. I found mine in a set of oilpan drainplug taps .. I had an 8 ball on my stock shifter for a while.
Old Dec 3, 2004 | 05:36 AM
Dale's Avatar
Engine: 350 S-TPI
thank you thank you
Time to hit up sears
Old Dec 3, 2004 | 06:39 AM
Dale's Avatar
Engine: 350 S-TPI
I just did some thinking. Are you refuring to the top of the shifter where the ball/**** goes?
I'm refuring to the connection down under the boot. I only have the bottom section of the shifter, and I'm putting this custom shaft on that.
dbrochard
Oct 3, 2015 12:43 PM
Linson
Sep 21, 2015 01:08 PM
Fronzizzle
Sep 8, 2015 12:10 PM
dbrochard
Sep 7, 2015 09:41 AM
tonys91rs
Sep 2, 2015 07:07 PM
