a pillar pod ?
Old Dec 3, 2004 | 06:47 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
a pillar pod ?
whats everyone runnin in the pillar pods. im gettin the dual pod and i donno what i should stick in there. i want air/fuel but i donno what for the other one. no super charger yet so i cant do boost and i dont run nitrous. i was thinkin vacuum. post pics of your gauges and who makes em cause i still gotta pick out gauges.
Old Dec 3, 2004 | 08:55 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Heres mine, the one on the bottom is a tranny temp gauge and the top is air/fuel
Old Dec 3, 2004 | 10:24 PM
MNformula350's Avatar
Auto meter 3 pod pillar with auto meter carbon fiber gauges (closest match to stock gauges) Top is Transmission Temp, Middle is Vacum gauge and bottom is air/fuel ratio.
Old Dec 3, 2004 | 10:43 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I've got a triple pod with trans temp, water temp, and A/F
Old Dec 3, 2004 | 10:44 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
A/F and vacuum.
Old Dec 4, 2004 | 12:48 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Right now I have temp and a/f ratio.Soon will be boost and a/f.
Old Dec 5, 2004 | 11:59 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
heres mine, top is a/f , then trans temp and then vacume. probably replace the vacume with a fuel pressure gauge.
Old Dec 5, 2004 | 12:18 PM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
The top one is an A/F gauge, the bottom one is a temperature gauge that has an adjustable setting to control one of my electric cooling fans. Wow....they look all scratched up in this pic, but they don't in real life
-Paul
Old Dec 5, 2004 | 04:49 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
how does one wire up a tranny temp gauge?
Old Dec 6, 2004 | 02:59 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Concidering it was a base model with only idiot lights...oil, temp, volts...
Planning to run digital guages that actually fit soon. This was a rush job so I could smooth and paint the dash guage cover. (had to relocate the guages from where they were mounted before)
Also going to go with an all digital dash, so the standard guages will be moved there. The pillar pads will then get whatever is left over...
Crap pic not linking...wtf! ok link to page on my site
Old Dec 6, 2004 | 10:54 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
3-pod from autometer. Awsome fit. Went with autometer Phantom gauges. Just thought there were the nicest during the daytime. A/F up top, fuel pressure in the middle, and vaccum at the bottom. enjoy.
Change to amber bulbs to match the dash at night. It kind of makes them less distracting and easier on the eyes. Looks good.
Old Dec 8, 2004 | 12:20 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Those look pretty cool
Old Dec 8, 2004 | 01:11 AM
XChris1632X's Avatar
Car: 83 Z-28
Engine: LG4 305
please others post more. i would also like to see some more night time pics of what different gauges look like at night. Timz2882 what kind of guage cluster do you have there. that think is sick. i saw one similiar in a car craft i believe. some place sells them with autometer gauges but they are like 500+ dollars. all of the other clusters on that page were for 67-69 camaros and chevelles. i just happened to see the 82-92 cluster on the bottom of the page.
Old Dec 8, 2004 | 02:40 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
its the one that Corvan Classic's sells. they have a few ads i think in car craft and a bunch of others. i got the cluster piece and wiring harness off of a member here that didnt use it. i think i paid $220 for the cluster and wiring harness. and then i bought all the gauges seperate. so i have about agood $600+ sittin there. heres a pic with the LED bulbs i put in it. looks 10x better in person and will look better once i get my new alternator which mine just decided to crap out on me on sunday.
Old Dec 9, 2004 | 08:31 AM
Car: 83 Z-28
Engine: LG4 305
is it pretty easy to see with at night either way with regular bulbs and the leds.
Old Dec 9, 2004 | 07:41 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
i have a sportcoupe base model and didn't have any of the regular guages from the factory, so mine are oil pressure, water temperature and voltage meter. i would like to come up with another place to put some more guages without looking too gawdy, but haven't figured any concrete ideas out yet. for some reason, other than a higher reading speedo, i really have no desire to put a regular guage cluster in it.
Old Dec 11, 2004 | 06:32 AM
GTABANDIT's Avatar
mine are exh gas temp ,fuel press ,and nitrous press
Old Dec 11, 2004 | 09:19 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i found its easier on my eyes at night to read the gauges. depends on the driver.
Old Dec 12, 2004 | 12:35 AM
Car: 83 Z-28
Engine: LG4 305
someone post some more day and night pics
Old Dec 12, 2004 | 03:37 PM
redraif's Avatar
Mine hits the dash bad though. Took some fitting to coax it in.
Frozer!!!
Jan 19, 2024 04:55 PM
91 zeee
Interior Parts Wanted
Sep 24, 2015 03:09 PM
aharvel50
Sep 21, 2015 07:31 PM
Fox118
Sep 12, 2015 09:29 PM
arod231
Aug 16, 2015 02:51 PM
