urgent help needed
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
urgent help needed
Someone busted my passenger window last night and to make a long story short I got my new window right here in front of me, got the the window crank out of the door and basically ready to install the new window.....one problem. How the hell do I slide the new window into the door? need to do this fast, thanks!
Car: 88 Camaro
Engine: 305 TBI
i had to replace both of my door windows afew months back. Start by removing the door panel, and use a vac to get rid of all the broken glass. Then raise the "window" up, and use a punch to knock out the center of the rivots, and then drill them out. (two or three located in the white clips) You also have to remove the felt guides from the top, that way the new window will go in the door. Be careful of the plastic triangle on the door because those things can easly break, if you rush. Hope this helps, sorry if I left some info out.
Zachattack0925
Aug 12, 2015 09:52 PM
